Sponsored by: CARiD
Headlight Motorrrrrrrrrrrrrrr!
Old Sep 21, 2007 | 03:30 PM
VINCE TA's Avatar
Angry Headlight Motorrrrrrrrrrrrrrr!
I Justchanged My Left Headlight Motor But Now When I Turn On The Headlights The Motor Goes Down And When I Turn Them Off The Motor Goes Up. I Need Help! I Don't Know What To Do!
Old Sep 21, 2007 | 07:17 PM
snake charmer's Avatar
you know the manual **** to twist your headlights up ?
in case you dont there is a rubber boot above the headlight . remove this , then turn the plastic **** that manually moves your headlights up and dwon . try ans turn it about half way then try to flip your lights up . you might have to play with it some to get it straight and find out which way up or down the gear is set .
Old Sep 22, 2007 | 08:48 AM
VINCE TA's Avatar
Thank You! But, I Already Tried For Over 2 Hours And It Still Not Working.
Old Sep 22, 2007 | 08:13 PM
XpEdItIoUs's Avatar
I would help but i never delt with this problem, Try to disconnect it when its down and turn the the lights off then reconnect it.
Old Sep 23, 2007 | 01:54 AM
jcvett56's Avatar
When you installed the motor you might have installed it incorrectly.
There is a black arm that moves when the motor operates, when you installed it you might have the black arm that has a hinge, par say, not in between the two stoppers; when your arm is moving, it is going where ever it feels.
I did the same thing when i did my install, look in your other headlight when its down and see if you notice what i'm talking about!
Hopefully this has helped you
Old Sep 23, 2007 | 07:24 PM
99nbmws6's Avatar
what he said happened to me too did that and fixed the problem
Old Sep 25, 2007 | 12:35 PM
jcvett56's Avatar
let us know whats going on, so we can become some more help!
