Sponsored by: CARiD
Lucas Oil Stablizer
Old Oct 8, 2007 | 12:47 PM
blakern's Avatar
Default Lucas Oil Stablizer
Any of u guys use this in ur LS1s?? I bought a 98 T/A about a year ago with 49K on the clock. When I did the first oil change I used 5qts of mobile1 5w30 and 1qt of lucas oil stablizer. Immediatly afterware I started hearing a slight ticking noise. Been like that eversense. I kept on useing this setup and never thought about it. Yesterday I changed the oil in my truck and used mobile and the lucas, and what do ya know I just heard a ticking noise. Any thoughts?
Old Oct 8, 2007 | 01:28 PM
ls1ws9ta's Avatar
switch to german castrol 030..you can find it at autozone.... before doing an oil change though run some seafoam in ur crank case for 20 miles then change ur oil... the ticking should quite down. mobil one is way to thin.
Old Oct 8, 2007 | 02:45 PM
dragonrage's Avatar
I never use 5w30. 10w30 for the win....
Old Oct 8, 2007 | 03:29 PM
dailydriver's Avatar
I would steer clear of ALL of the Lucas oil stabilizers (both mineral AND synthetic). If you check over on www.bobistheoilguy.com, you'll find that it's nothing but "bright stock" oil, which really does not help anything.
If you feel compelled to use additives (or "thicken" your oil), at least use one that also contains some useful ingredients, like Valvoline Synthetic Oil Treatment (VSOT). This stuff has a big dose of phosphorus, zinc, and molybdenum, but it also contains viscosity index improvers, so I would hesitate to add it in the winter (if you live where it gets cold).
Torco MPZ, Schaeffers 131, and Specialty Formulations' additives are also very good sources of "good" moly, which do not thicken the oil already in the crankcase.
