Sponsored by: CARiD
Help Turn Signal Problem
Old Oct 17, 2007 | 04:23 PM
koz28's Avatar
Default Help Turn Signal Problem
I have a 1998 Z28 and when push the turn signal lever down to go left it works fine but the lever does not return to the normal position after turning. If I use the right signal the lever goes back up by itself so this just happens when I use the left signal and I have to put it in the normal position myself to turn off the signal. Is this a big fix? I also think I heard something fall off it inside when it first happened like a part fell off. Any ideas appreciated TYIA
Old Oct 17, 2007 | 04:59 PM
ncnumber8's Avatar
It sounds like your turn signal switching mechanism needs replacing. And yeah, it is a real pain to replace. Getting the steering wheel off isn't too bad (you still need a steering wheel puller to get it off), but getting that mechanism out is a real pita. I'd suggest taking it somewhere and having it done.
Old Oct 17, 2007 | 05:22 PM
koz28's Avatar
Is this a costly repair? because i might just live with it for now if requires my paycheck to fix the stupid thing
