Sponsored by: CARiD
A/C doesn't work after header/ORY install
Old Oct 24, 2007 | 01:13 PM
HuggerOrangeZ's Avatar
Question A/C doesn't work after header/ORY install
Well about 2 months after I had headers, ORY, cut out and stall put in the car my A/C doesn't work anymore. It used to work perfect before but now nothing. I don't know if anything is related but I find it weird to stop working out of no where.
If anyone might know what the problem is, any help would be appreciated. I would hate to have to go to a dealer and pay big $$$ to fix something that I could fix.
Thanks
Old Oct 24, 2007 | 07:22 PM
2001NBMZ28's Avatar
If it worked fine for 2 months after all the work was done it's nothing the shop did, something else is going on. Could be a leak, electrical problem, etc. I'd bring it to a local shop that does AC and have them look at it before going to a dealer.
Old Oct 24, 2007 | 07:30 PM
98LS-WON's Avatar
Check and see if your headers didn't melt any wires.
Old Oct 25, 2007 | 12:22 PM
bczee's Avatar
Get a gauge and see if you have pressure on the low and high side. Is the A/C compressor engaging ?
Check all of the connector, high side pressure switch, compressor clutch, etc. and the fuses ?.
Have you tried to bypass the switches to engage the clutch ?
Old Oct 25, 2007 | 03:50 PM
It does not seem to be engaging the compressor.
I would think if anything melted it would have been sooner than 2 months of driving, but I guess you never know.
I'll check all of the connectors and fuses and see if something is loose.
Thanks for all of the possibilities.
