Flashing Security-Resistor question
I measured the resistance on my key pellet and it read 1.47 on the 20k setting....so i went to radio shack and bought two resistors. One that is a 1-ohm 10 watt with a 10% tolerance, and another at .47 ohm 5 watt 10% tolerance.
Did i buy the right ones? The guy at radio shack really wasn't much help. He kept saying it would probably work if they were mounted in parallel, but he's never done resistors in parallel so it may not work...i think he was pissed i interupted him watching star wars...
I bought them before work otherwise i would just try them, but i have to wait till im off to try and i rather know before i drive out to where my car got stranded.
any insight would be much appreciated!!
if it read 1.47 on the 20K setting, that means it was 1.47K. You need a 1Kohm resistor and a 470ohm resistor, and then wire them in SERIES, not parallel, to get 1.47Kohm. Also, get the lowest % tolerance that you can.
