Sponsored by: CARiD
Help!! I lost the headlight pivot bolt
Old Nov 13, 2007 | 06:29 PM
bob320fa's Avatar
Default Help!! I lost the headlight pivot bolt
So I went to replace one of my headlight motors and lost the only bolt I can't seem to replace. It's the bolt w/ plastic bushing that attaches the headlight assembly to the bracket and allows the headlight to pivot up and down. It has a torx pan head, a 10mm shoulder, and then a 6mm screw end, and the plastic bushing.
I've tried everywhere including junkyards and the dealer but, the bolt is not serviced separately. It is part of the $750 headlamp assembly. Go figure. Until I can get it I have a huge headlight hole!
Old Nov 14, 2007 | 05:52 PM
Kujo806's Avatar
I don't know if you already saw it or not, but I replied to a similar post a few days back. I had the same issue about 1-2 years ago. I used a similar shoulder bolt (6mm I believe, but the shoulder was thinnner than the stock). I got a nylock nut/washer for it as well as a nylon spacer for the shoulder. I hand sanded the spacer down to the point where it filled the big "pivot hole" just about perfect. As ghetto as it sounds, it works great actually. Been working fine for well over a year now.
https://ls1tech.com/forums/general-maintenance-repairs/813693-firebird-headlight-probelm.html
Old Nov 14, 2007 | 11:14 PM
bob320fa's Avatar
I think I might have to try that. I'm not having any luck finding a replacement so far. You would think it would be easier to find
Old Nov 18, 2007 | 08:37 AM
Viper's Avatar
I had to make one too earlier this year, no luck on finding a replacement.
Old Nov 18, 2007 | 09:44 PM
letsrun97z's Avatar
dosnt autozone sell those in the diy section
Old Jan 3, 2008 | 01:29 PM
CWW17's Avatar
For anyone else having this problem, I just bought 2 of them from HawksThirdGenParts.com Price was a little steep but it's OEM. $30 Shipped.
