Sponsored by: CARiD
dash, interior, and head lights flicker!!
Old Nov 15, 2007 | 06:12 PM
tording99Z28's Avatar
Default dash, interior, and head lights flicker!!
Hey guys. I have a 99 Z28 and I have noticed that at night time when I have the lights on the dash lights, interior lights, and headlights flicker just a bit. Most of the time it is barely noticeable and other people can't even tell it is doing it but I can tell because I am **** like that. I have done a search on this topic and it seemed that there were a few different things that people did to fix this problem. From what I could tell it seemed most people replaced the alternator and it fixed the problem. My car has 118k miles on it and I am pretty sure its the stock alternator. I am going to clean up the grounds on it for sure since that is easy but do you guys think I should try a new alternator as a first step to fixing this? thanks in advance.
Old Nov 16, 2007 | 06:36 AM
SparkyJJO's Avatar
I wouldn't replace it right away, I'd have it tested first.
Old Nov 16, 2007 | 09:08 AM
johnnydi's Avatar
I have a 2002 TA that only has 20,000 on it and it does the same thing. I noticed a split second flicker in the headlights but I guess now I'll notice the dash too I'm not going to worry about it unless it gets worse.
Old Nov 16, 2007 | 10:19 AM
Luder[PAK9]'s Avatar
https://ls1tech.com/forums/general-maintenance-repairs/812393-lights-flickering.html
Old Nov 20, 2007 | 06:48 PM
So yeah, replaced the alternator today and it solved the problem. No more flicker. Thanks guys.
Old Nov 22, 2007 | 11:49 PM
enos44's Avatar
i have that problem quite bad actually, but when i test my alternator it shows that is throwing 14-15 volts, and i also have a pretty big stereo system so im not sure what to do?
Old Nov 23, 2007 | 09:03 AM
Greggy's Avatar
if it only does it at idle then the alt. will test out ok.
The replacement alt. will probably start to flicker again after a few thousand miles, sorry to say. Mine was flickering for years and then at 95k it went out and the replacement AZ Gold did not flicker for a few months... but then it start to.
