Sponsored by: CARiD
The Best Electrical tool ???????
Old Nov 26, 2007 | 11:33 AM
95TransAm_ToM's Avatar
Default The Best Electrical tool ???????
What is the best and cheapest Diagnostic computer scan tool out there for a 95 trans am with an Lt1 ?
Old Nov 26, 2007 | 11:38 AM
Derek @ EDO's Avatar
That just reads codes?
Old Nov 26, 2007 | 02:24 PM
haacer's Avatar
I like AKM and Tunercat. I bought a cable from AKM and downloaded Tunercat to change fan temps and play with fuel tables.
I also found a program online called "freescan" which gives real-time sensor outputs (VSS ECT etc..). There's another one that I have which was also free and gives codes.
Going that route, you'll need a laptop and a cable from AKM ~$120.
Here's a link from Tunercat to diagnostic software sites...
http://tunercat.com/tnr_desc/links.html#scan
Stand-alone scanners tend to be expensive. If you car was OBD II you could get something at Harbor Freight that would give you codes for like $30. The cheapest OBD I scanners that I've seen start used at ~$500+ on Ebay.
Maybe someone else knows of a cheaper one. I'd love something that could read the ABS and airbag codes from my 1995 Camaro.
Also, shbox gives the follow diagram for converting an OBD I scanner to the OBD II plug.
http://shbox.com/1/xraycable.jpg
