Sponsored by: CARiD
need help fixing cruise control
Old Nov 26, 2007 | 09:09 PM
jonny_boy's Avatar
Default need help fixing cruise control
so a couple weeks ago i replaced my clutch master cylinder by myself.things didnt go a smoothly as i hoped they would.anyway long story short while working under the dash im pretty sure i broke something and was wondering what i might have screwd up.any help would be great.
Old Nov 26, 2007 | 09:12 PM
jonny_boy's Avatar
sorry if this is the wrong froum
Old Nov 27, 2007 | 09:31 PM
haacer's Avatar
When I bought my car the cruise didn't work.
Just by looking around under the driver's side dash I noticed a connector unplugged. I plugged it back in and it's good as new!
If it was working before you did the master cylinder, start by looking in all the areas that you have been. Chances are you'll find something unplugged or out of adjustment. For instance, brake light switch can keep cruise from coming on. If your car is a manual, there is a switch on the clutch etc...
Old Nov 27, 2007 | 10:02 PM
01'WS6's Avatar
There is actually a fuse for the cruise control. Its the same as the a/c fuse. May wanna check that. Its under the hood in the fuse box on the drivers side.
Old Nov 27, 2007 | 10:24 PM
E V I L's Avatar
Mine is also not working either. When I bought my formy it worked once on the highway then not after that and then it worked another time a few weeks later, now nothing. Any ideas?
Old Nov 28, 2007 | 01:33 AM
Demon Of Dreams's Avatar
mine stopped working after the little spring on my clutch pedal broke off, I've not bothered to fix it yet
