Sponsored by: CARiD
Headlights Problem..Need Help
Old Dec 2, 2007 | 01:14 PM
yodabam's Avatar
Default Headlights Problem..Need Help
Hello,
I have a 98 TA WS6 and the Passenger side headlights decided to stop 'working'.
Drivers side works perfect, on Low beam the passenger sides are extremely dim (Like they aren't getting enough voltage) and when on Hi Beam the passenger side doesn't light up and all.
Has anyone seen this before??
I have replaced both of the headlights with no change same problem occurs.
Thx in advance.
Old Dec 2, 2007 | 02:30 PM
haacer's Avatar
Sounds like a bad ground. I'm sure someone else can advise you of the location/color of the headlight ground. To check I would run a jumper wire from the frame to the ground terminal on the headlight and see if there's a difference.
