Sponsored by: CARiD
Cold start, car dies
Old Dec 4, 2007 | 05:59 PM
amich187's Avatar
Default Cold start, car dies
I drive a '98 Z28 Camaro as my daily driver. It is all stock except for Flowmasters. The past couple of weeks have been around or below freezing outside, and several times I have started my car, only to have it die on me. It will start as usual, but after a few seconds it will slowly hit low RPMs and die, but starts back up when I turn the key again. Is this just the cold weather, or is something else up? I was thinking plugs, the car has 112k miles on it and I'm not quite sure when the spark plugs were last changed.
Another question, my speedometer likes to stick a bit. It increases in increments of like 3-4 mph, and when I stop it takes a few seconds for the speedometer to come back down to zero. Is this a problem with a guage, or sensor at the trans? Could it have anything to do with tire size, the car originally had stock 15" wheels/tires, but the previous owner put 18" Armano wheels on the car.
Any help is much appreciated. Thanks.
Old Dec 4, 2007 | 06:37 PM
Gun5's Avatar
check connector on trans and take the sensor out clean it + connector and replace if it keeps doing it
Old Dec 6, 2007 | 09:28 PM
amich187's Avatar
I've cleaned the sensor now and the problem persists. Just curious, does it have anything to do with tire size? Or is it just the sensor? I ordered a new sensor tonight, hopefully it will help.
