Sponsored by: CARiD
Hazards Dont Completely Work
Old Dec 27, 2007 | 10:28 AM
badazz99ta's Avatar
Default Hazards Dont Completely Work
all my lights work fine, headlights, brake lights, marker lights, and blinkers. but when i throw my hazards on they blink very fast and very light. you can barely see them. what the hell could this be. mods are in my sig if that matters. thanks.
Old Dec 27, 2007 | 10:54 AM
Levman74's Avatar
have you checked the hazard flasher itself? I had the same problem with another car, the spring inside just would barely hold the circuit before returning to home.
Old Dec 27, 2007 | 11:23 AM
badazz99ta's Avatar
so im assuming you can take the hazard button off. well i will go out there and see what i can do. thanks man. ill letcha know what happens.
Old Dec 27, 2007 | 11:36 AM
badazz99ta's Avatar
ok. i checked the spring and stretched it out quite a bit. put it back in and still the same. thanks anyway. any other suggestions.
Old Dec 28, 2007 | 02:42 PM
Levman74's Avatar
No, I was referring to the actual flasher, the thing that opens and closes the circuit, not the button, the flasher should be located under the dash on the driver side
Old Dec 28, 2007 | 03:02 PM
badazz99ta's Avatar
ahhhh...ok. ill check it out.
