Sponsored by: CARiD
is it over for my motor?
Old Dec 30, 2007 | 06:32 PM
griever's Avatar
Default is it over for my motor?
k at high rpms it started throwing white smoke.........and i got the smell of antifreeze......a little bit of white smoke came from under the hood.........but then when i was driving normal......nothing drives fine no codes...........at idle no smoke.........anybody cuz my brother scared the **** out of me saying its the begining of the end for my motor..........anyone help please!!!!!!!!!!!
Old Dec 30, 2007 | 06:45 PM
lifeisgood's Avatar
check you engine oil. if theres a milky residue in it well theres a bad thing going on. but he prolly saw the smoke and thought it was white. sometimes the blue looks white.
Old Dec 30, 2007 | 08:14 PM
Mike44138's Avatar
Sounds like a leaky head gasket. Check the oil as above and check the coolant for oil.
Old Dec 31, 2007 | 07:10 AM
qwk93ta's Avatar
I agree with this, but there should also be a loss of power too.
Old Jan 2, 2008 | 02:05 AM
griever's Avatar
oil is fine, antifreeze is fine.......only seems to smoke at high rpms........oh and it does have excess antifreeze....oh and no loss of power drives fine......... it hasnt been tuned since header install could that be it.......anybody know
Old Jan 2, 2008 | 02:10 AM
waldershrek's Avatar
Almost sounds like a head gasket although it is strange it only did it on start up. Maybe if you're lucky you caught it right in the very beginning.
Old Jan 2, 2008 | 11:17 AM
1999Transamman's Avatar
Watch your coolant level, if your head gasket ate it, you'll be sucking down coolant. Mine did at least, I pulled it right into the shop and tore it down, not worth destroying an engine over a simple head gasket.
Old Jan 2, 2008 | 11:30 AM
_JB_'s Avatar
Were you ridding the high RPMs down? Like did you take it up to 6000, left it in gear and just coast? Could be valve seals.
Old Jan 4, 2008 | 12:15 AM
griever's Avatar
the excess coolant is normal now........guess that was the cloud of smoke that came up...... took it too a mechanic shop they checked it and said nah it was fine........weird.....i told them about the smoke of clouds and they said maybe it just slipped through cuz it was under hard stress.....or cuz it was running lean........they said it was fine though......they said id know if i blew the gaskets.........confused oh and its an automatic.......so computer did all my shifting..........
