Sponsored by: CARiD
Security light
Old Jan 9, 2008 | 04:42 PM
rayvendawn's Avatar
Default Security light
I just bought this 02 ws6 and the security light on the dash is on and I thought at first that it was because I don't have the keyless entry to it.
Today I had someone come out to the house and install the original equipment on it and the light still didn't go off.
What could cause this light to stay on?
Old Jan 9, 2008 | 07:45 PM
1999Transamman's Avatar
If you run a diagnostic it will probably say P1626 Anti theft system, it might be your key, try a spare if you have one, or clean the key with rubbing alcohol. There are alot of threads regarding this, do a search, you should find something. I just had the same issue with mine, but it wouldnt start at all, I tried the gauge fuse (10A), it wasnt blown but it was a little loose, pressed it back in, no problems since.
