Sponsored by: CARiD
Radiator Leaking Time To Up Grade Need Help!!
Old Jan 13, 2008 | 07:41 PM
TX98Z28's Avatar
Default Radiator Leaking Time To Up Grade Need Help!!
Ok this happened before and i fixed it with a bottle of Liquid Glass Metallic SEAL UP. My Radiator has a leak on the right side (looking from front of car) it appears to be where the aluminum metal edge crimps around the black part of the radiator. I'm gussing there is a crack on the black part under that metal edge. This is where the SEAL UP appered to make a white residue that sealed the crack the first time this happened. Now my dad say's screw the SEAL UP again and just to buy a new radiator. So i guess im getting a new radiator and now im trying to figure out if i can fit a bigger radiator where the Piece Of Shi* stock one is now, because if im going to spend the money on a new one its going to be better than the first.
Need opitions on after market radiators that will fit my 98 Z28.
