OMFG window motor install
Of course I found the shoebox guide AFTER I did my motor the hard way....
You might need some extra wire - and you won't need the extra fuse but from a wiring aspect its the same.
I've had the door panels off more times than I can count - I can have it off or on in about 2 minutes - but that little door lock continues to screw me every time. Looking at the door (with the panel off, of course), you will see 4 large rivets. The place to drill to expose the motor rivets are:
1) From the top left one, move 1 3/8" to the left, and then 1" up.
2) From the bottom left rivet, move 2 1/4" to the left, and 1 1/2" up.
3) From the bottom left rivet, move left 1"...it's right at the top edge of that hole.
I actually got the tape out and measured this out. Hope it helps!
It's a crap shoot no matter what. You could just as easily go through all that work and have one of the new ones pucker out in a couple months.
