Parking light question
Your new bulb may also be bad. Suggest switching your left and right bulbs to make sure.
I took it off, put it back on and it works normally for a couple of hours, later on in the day it stops
It may sound like its loose or something, but whenever i turn the headlights on then the parking light is working back to normal
Anyone have an idea?
There are two filaments in the bulb. One is illuminated when the headlights are on and the other is controlled by the DRL module. (The DRL Module sits between your bulb and the turn signal imputs.)
What kind of car do you have? (Firebirds and Camaros have slightly different wiring.)
When you have the parking light problem again, can you check your turn signals and hazard flashers to see if they work normally? If so, do they work normally with the headlights turned on also?
