Sponsored by: CARiD
anti-theft problems
Old Feb 11, 2008 | 09:46 PM
brandon2000z's Avatar
Default anti-theft problems
i have a 2000 z28 and i havent been able to get it started the last couple of weeks. when i try to turn the car on the security light pops on and i cant get it to start. it has been doing it for awhile now probably 3 months but i used to be able to wait a little while the it would start again but the security light would stay on and i just got a new keyless entery and a new key today to see if that was the problem but it didnt work. can anyone help me please?
Old Feb 11, 2008 | 09:48 PM
iverson387's Avatar
did you try and leave the key in the ignition in the run position for like 10 minutes then try and start it. happens to me now and then
Old Feb 11, 2008 | 09:53 PM
no ill go give that a shot really quick
Old Feb 11, 2008 | 10:16 PM
it worked it started then i turned it off and it started again they on the next try it wouldnt start
Old Feb 12, 2008 | 01:16 AM
tripps's Avatar
Happened to me a couple of times. The resistor in the key gets old and loses its ability to let current pass through the resistor and turn off the anti-theft system and start the car. Just leave the key in the ignition until the light turns off, or you will have to replaced the key. If you have the spare set that you never used try using that one from now on. Should solve your problem.
