Sponsored by: CARiD
Ticking Lifter
Old Feb 18, 2008 | 07:50 PM
LS1Silverado05's Avatar
Originally Posted by kw's01z28
normal for an ls1 dont worry about unless it gets louder over half of ls1's i have heard make the same noise. it used to drive me ******* crazy but then i heard some vettes making the same noise so i was like **** it they payed twice as much for the car and they put up with it so i guess i can also
LOL....Yea I test drove a Z06 with 13,000 miles and it had the LS1 racket....I was like screw this...but knowing what I know now, I wouldnt of freaked out.
Old Feb 18, 2008 | 08:10 PM
dirtdevil99's Avatar
Sounds kinda like what I had which was just a broken stock rocker arm. Easiest thing to do is just pull your valve covers and check your rockers and pushrods. Or just change your oil and see if there are any needle bearings on the end of your oil plug (if it's magnetic).
Old Feb 19, 2008 | 10:50 AM
badazz99ta's Avatar
well say he has a bad lifter. what would happen if he does nothing about it. cuz mine sounds exactly like that, just not as loud. i plan on seafoaming it very soon. i just dont want to do any permanent damage if i dont change the lifters.
Old Feb 19, 2008 | 10:56 AM
keliente's Avatar
Eventually if the lifter craps out, you'll start getting a lot louder noise, and a misfire. The misfire can lead to other things like running rough, being too rich/lean, fouling spark plugs, poor driveability, etc.
Old Feb 19, 2008 | 02:27 PM
badazz99ta's Avatar
thanks for the info. if the seafoam doesnt work, which i pray it does, then it looks like i will be getting some new lifters and tearing my baby apart...again.
Old Feb 19, 2008 | 03:47 PM
Arc00TA's Avatar
My car has made that sound the entire time I've owned it. It gets a little louder right after I change the oil, but it goes back to a normal tick tick tick after like 10 miles. I've never noticed any problems so I consider it normal now. Freaks the ford guys out though, they're not sued to weird noises.
Old Mar 20, 2008 | 02:17 AM
GMmexican's Avatar
My car has no ticking issues, only noise you should hear on a stock healthy ls1 is piston slap
Old May 27, 2008 | 05:18 PM
mavedawg04's Avatar
Same noise here. Pulled the valve cover off and found it to be the number 1 piston on the exhaust side. Little if any oil was coming out of the pushrod. Pulled the rocker arm and checked everything out. Nothing was stopped up so the only thing left is that the lifter is bad. Pretty shitty on a 22,000 mile T/A. Well I'm a mechanic so any questions just send them my way and I'll tell you all I know haha.
