Sponsored by: CARiD
Water in the oil?
Old Feb 14, 2008 | 02:49 PM
rayvendawn's Avatar
Default Water in the oil?
I just did my first oil change on my car, I did it 2,000 miles early because my oil pressure indicator showed my oil pressure was way down.
I knew I had a pretty bad oil leak and thought I might be running low on oil.
I checked it and found that there was water all over the cap and what looked like butter lol.
What does this mean?
Old Feb 14, 2008 | 03:26 PM
TCW's Avatar
TCW
had the same thing, apparently its common in cold weather
Old Feb 14, 2008 | 06:21 PM
Spink's Avatar
Pretty normal. It will be worse if you let your car idle a lot. As soon as it's warmed up drive it, don't let it idle excessively if you're doing that now. It shouldn't take more than 5 minutes to warm up. Nothing to really worry about though you just might not want go as long between oil changes.
