Sponsored by: CARiD
Belt Squeak
Old May 28, 2008 | 05:23 PM
9000th01ss's Avatar
Originally Posted by Viper
Yes. There are 4 that can be taken off the car and repacked with grease. 1/2 hour job, 3 are 15mm, 1 is a T-50 torx.
Which is a waste of a 1/2 hour, wasn't the cause of my belt noise.
Old May 28, 2008 | 06:05 PM
Viper's Avatar
I was answering CK9887's question; read it.
Old May 28, 2008 | 10:04 PM
9000th01ss's Avatar
Yea and I was letting CK9887 know that greasing the pullies is a waste of time; understand it.
Old May 29, 2008 | 01:23 AM
CK9887's Avatar
So what would you suggest?
Old May 29, 2008 | 06:10 AM
Viper's Avatar
Dang. I'm trying to help the guy and you just want to state what did not work for you. He specifically asked 'theres also an idler pulley down by the AC tensioner right?' and I answered yes. I then went on to state a possible solution. I am now FULLY aware it did not help you but MAYBE it can help him.
What have you done for a solution? Perhaps you can help us?
Old May 29, 2008 | 09:53 AM
9000th01ss's Avatar
My problem was a worn out tensioner. It's crooked making the belt out of alignment.
Old May 31, 2008 | 01:23 PM
Black35thz28's Avatar
My Dad's corvette also has a squeak. It has been driving him crazy he's changed four belts some pullies and regarless of what belt he removes there is a squeak. When the're both off there is no squeak so Im guessing it's the balancer and that looks like a difficult job.
Old May 31, 2008 | 06:25 PM
9000th01ss's Avatar
What year is the vette?
Old Jun 4, 2008 | 04:51 PM
okarcheta's Avatar
I also have the same noise. I just got a new idler pulley. Tried to take it off. I wont come off even used a cheater pipe. It just broke my torque bit. Any suggestions.
Old Jun 5, 2008 | 01:52 PM
CK9887's Avatar
Well I took off the serpentine belt and cranked it up for a second and still have the squeak... So Obviously its one of the two pulleys on the AC system
Old Jun 5, 2008 | 02:29 PM
9000th01ss's Avatar
This is my post about my AC belt noise, three belts, it ended up being the tensioner worn out and crooked.
Old Jun 6, 2008 | 02:16 AM
  #32
kny3twalker's Avatar
just replaced mine cause it squeaked like crazy and was crooked
it was 70 dollars from my dealer
Old Jun 6, 2008 | 09:57 AM
  #33
1BADTALS1's Avatar
my belts squeak if its been raining outside... if it rains at night and i go to drive it they squeak for about 5-6 miles and it slowly goes away...
Old Jun 8, 2008 | 04:22 AM
  #34
The corvette is a 2001 zo6 asp underdrive pulley shot.
Old Jun 8, 2008 | 10:40 AM
  #35
z28_YOU_HO's Avatar
Not sure if the belts are set up is the same as my ls1 Z but i had the same issue and it was the a/c belt and tensioner pulley...no more squeak
Old Jun 8, 2008 | 10:54 AM
  #36
9000th01ss's Avatar
Yea, I might have said I replaced mine but I didn't.
I took it apart and rotated the two bushings 90 degrees, they only wear on one side. Also greased them.
It runs straight and keeps the belt aligned.
I wanted to put some miles on it before it put this on here.
Old Jan 6, 2009 | 11:50 AM
  #37
QuickdomesticRacer's Avatar
I just replaced my waterpump, could there have been some manufacturing issue w/ the pump and where the tensioner bolts up?
I tried replacing idler and tensioner pulleys squeak is still there. New Waterpump. New alternator(overddrive pulley). I had to get a 1 1/2" shorter belt for the overddrive, now there is more tension on the tensioner then before.
Taking main ACC belt off, no squeal, so not any of the A/C belt components. Squeak is loud when cold or haven't been run in awhile, and quiets down after running for awhile, but never goes away. Gets louder at higher RPMs
Old Jan 9, 2009 | 09:35 PM
  #38
sic2001's Avatar
I have the same squeek and had a new motor dropped in and it still squeeks...the only part off the old motor was the waterpump and oil pan (new A/C compressor) So waterpump is what I would say. My squeek continues sometimes after the car is shut off and belt is no longer spinning so has to be the" thingy" in the pump.
Old Jan 9, 2009 | 10:03 PM
  #39
9000th01ss's Avatar
The thingy in the pump stops with the engine.
Your squeak is probably one of the fan motors.
Old Jan 4, 2012 | 12:19 PM
  #40
System_Error_117's Avatar
Could even been the ac compressor itself, you said that turning the a/c on and off makes it change the sound. I've had two LS1 Trans Ams and the they both squeaked when I bought them till I replaced the idler bearing in the ac compressor itself. The bearing allows the pully to spin even if the a/c is switched off and is activated using magnets. I've found as the bearing wears the magnetic plates move closer together and scuff/squeal.
