Sponsored by: CARiD
MAP sensor high voltage
Old Feb 18, 2008 | 10:06 PM
HeavyWeight's Avatar
Default MAP sensor high voltage
My car is throwing a code showing a code of the above, how do i need to fix this.
Old Feb 18, 2008 | 10:24 PM
keliente's Avatar
You can start by having a look at the MAP sensor. It is a small rectangle on the back of the intake manifold. It is probable that either the sensor is bad, or perhaps the wiring has gotten smashed up/damaged.
Old Feb 18, 2008 | 10:52 PM
ae13291's Avatar
yea, you may need to remove the manifold
