squeaking in the engine bay area
Also that grease tip works pretty good as well. saves on $$. Ive done replaced 1 pulley so far and did the grease trick. Only down fall I see to this is the rubber gasket getting damaged over time from popping it in and out with a screwdriver.
yeah i'm new with all this... thanks. can you tell me where perhaps? thanks
