Broken widow washer
What do you guys recommend? Thank you. You will have to remove the screened cover under the wiper blades.
If you have a hard mass clogging the line or the nozzle, you can also hook up a vacuum pump (from a brake bleeder system) to the line, dip the nozzle in water, and then suck water backwards through the line.
Not sure about the F-Body removal - did the above on a truck with a similar problem.
