Sponsored by: CARiD
The Infamous Ticking
Old Mar 7, 2008 | 12:14 PM
badazz99ta's Avatar
Originally Posted by Ponch95
I had the exact same issue before and could never figure it out, finally dropped the pan when I changed my K-member and come to find out the connecting rod bolts were slightly scraping along the splash guard and it also left little metal shavings. Hope this helps.
so how did you fix it. and was it very hard to do. did you have to buy any new parts. this sounds like what it might be, because it is a lot louder from underneath the car. thanks man.
Old Sep 25, 2008 | 11:45 AM
badazz99ta's Avatar
i updated my first post...it turns out i have a broke lifter!!!!!
Old Oct 1, 2008 | 08:18 PM
87 grand's Avatar
Default Ticking
Are you changing out all the lifters or just the broken one ? Should you change all the lifters on that side of engine ? ( all 8 )
Old Oct 1, 2008 | 09:05 PM
badazz99ta's Avatar
well I was doin a head swap so I put in all new ls7 lifters. I'm sure u ''could'' just replace the one lifter. but I woud go a head and take off the other head and replace all lifters and put in some ls2 lifter trays. they r cheap, like $18 or so.
Old Oct 1, 2008 | 10:13 PM
Medic/Z28's Avatar
I've had both, the bad lifter and the exhaust leak. Glad you found the problem. Those LS7 lifters are pretty good. My exhaust leaked around the clamps and the Y merge had a crack.
