Brake problem....help!
Second problem -- I drive a CETA firebird.....but my calipers are grey and not black. Wtf mates?
I assume the bolt you lost was one connecting the caliper to the bracket? If so, these bolts come from the factory with tread locker on them. (The tread locker helps keep the bolt from vibrating out.) If you have had your brakes changed in the past, they were probably put back on with out the thread lock.
Thanks guys, this is pretty helpful.
You just need red thread locker. (Its a liquid, sold in auto parts stores where the glues and another small tubes of "stuff" are.) They may also have the same thing in a paste, which comes in a chapstick style tube. (I like this version as I find its a little less messy.) If you've never used it before, the guys at the counter can show you how.
Today just must not be my day -- my drivers side window now is stuck half-way open, it won't budge either way up or down. I'll go ahead and admit that I might not have been thinking because I turned the car off, rolled the window up, and it quit working half-way. ARGH. Help....again?
Your motor is probably on the way out. When your engine is off, the motor gets less power and isn't as strong. Turn the engine on and the window will probably go up. If not, the motor is now bad. You can tug up on the glass (give it a little help) while you try to put the window up - which should get it up for you until you can make a permanent repair.
The main culprit is bad power being delivered to the motor, (hence, the power drop when the engine is off makes things worse) so when you get in there to replace your motors - I'd suggest installing the relay kits folks talk about on the site.
