Sponsored by: CARiD
Maf,,code
Old Mar 17, 2008 | 06:16 PM
99camaromike's Avatar
Default Maf,,code
My Car Is Running Fucked Up,,,the Code Is The Mass Air Flow Senser,,,,tryed 2 Ones,, Nothing Changed,,any One Know
Old Mar 19, 2008 | 08:55 PM
Camaro_Z28's Avatar
A maf code isnt always a maf. A few common probs are a vacuum leak anywhere after the maf can cause the maf code and a running problem. A manifold press. sensor will cause it, and also a faulty pcm. Those are a few places to look, a vacuum leak is the most common. I get MAF codes all the time at work, when I have problems with the other things i mentioned above. Good luck, I hope this might help
Old Mar 19, 2008 | 11:07 PM
mikenews's Avatar
Clear the codes and start over.......
