Sponsored by: CARiD
Issues with Evap system
Old Mar 19, 2008 | 10:30 PM
Slick02WS6's Avatar
Default Issues with Evap system
I was getting the P0452 code every now and then so I decided to change the sensor over the winter to fix it. I took it to get tested for emissions and it failed because its now throwing the code every 5 min. The sensor is brand new, what else can I check?? The car has always run with a little hesitation since day one. I brought it to the delear 3 weeks after I bought it and they said everything was fine. I just changed the oil and cleaned the air filter. I replaced the plugs last summer and nothing changed. I'm thinking I might have a bad computer. I pulled the plug on the MAF and nothing happened, no light, not even a bump in the idle.
I have to pass emissions by the 31st so I can renew my lisc plates. What else is there for me to check??
Old Mar 21, 2008 | 06:55 AM
lonala's Avatar
Could it be the gas cap
Old Mar 26, 2008 | 11:08 AM
Slick02WS6's Avatar
I have replaced now BOTH gas cap and SENSOR in the tank and its still throwing the same damn code. What else is there to fix or replace ??? This code is driving me nuts and it wont pass emissions with it happening and I cant renew my lisc plates.
Old Mar 26, 2008 | 11:38 AM
2001NBMZ28's Avatar
Maybe you can find the answer reading through www.gearchatter.com/viewtopic9347.php
Old Mar 28, 2008 | 12:19 AM
fuseone's Avatar
just a guess but maybe the wiring?
Old May 6, 2008 | 04:11 PM
massls1guy's Avatar
Did you figure out what the problem was?
