Sponsored by: CARiD
Squeaking while turning
Old Mar 21, 2008 | 04:10 AM
I Go To Costco's Avatar
Default Squeaking while turning
My car has a weird squeak while turning at low speeds, like in a parking lot where I'd rotate the wheel a lot, opposed to on the freeway where I just turn it a little bit.
I don't think it happens when the car's hot, after driving for a while and pulling into the driveway I don't notice it. I always notice it when I start it up in the morning though. I could just be oblivious though...
search came up with nothing like this
Old Mar 21, 2008 | 09:44 AM
staringback05's Avatar
strut mounts or ball joints...
Old Mar 22, 2008 | 02:21 AM
02T/A-WS6's Avatar
sounds like you might have a power steering pump issue with out knowing much. maybe check the level of fluid in it. Kinda need more info on the symptons
Old Mar 22, 2008 | 02:45 AM
Joshiedoom's Avatar
My tie rod ends did that.. replaced them. took measurements so there was no need for a front end alignment. Still got a wierd pop. Father(ASE mastertech) said it was strut mounts... so.. yeah.
Old Mar 24, 2008 | 02:06 AM
mtxfrk2k1's Avatar
get it checked soon... most basic "Muffler shops" will give you a free estimate to tell you what it is.. ball joints = bad news if you do alot of twisty driving.. i would be very careful on them/ not drive it..
