Sponsored by: CARiD
turn signal problem?>
Old Mar 25, 2008 | 10:31 PM
link138's Avatar
Default turn signal problem?>
I Do not have use of them anymore, I can push the stick up and down but nothing happens, no light in the cluster, no noise, no exterior blinking lights. I changed all the fuses and still nothing....
I am assuming a relay somewhere is busted, any help or ideas?
Old Mar 26, 2008 | 01:14 AM
02BlackMachine's Avatar
your best bet would be to remove the signal stick and run and check the wireing, if u replaced all the fuses its definitely ur wiring
Old Mar 26, 2008 | 10:18 AM
383lt1impala's Avatar
Same thing happend to be it was working good one day and the next nothing.
Old Mar 26, 2008 | 12:00 PM
link138's Avatar
what did you do to fix it?
Old Mar 27, 2008 | 09:38 PM
link138's Avatar
anybody else????
Old Mar 27, 2008 | 10:45 PM
sevenstarsfall's Avatar
If the fuses are good, check the flasher unit if thats good, check the wiring and if thats good you probably need a new turn signal switch.....lets us know what you find, goodluck
