Sponsored by: CARiD
Fan Fuse issues
Old Mar 28, 2008 | 03:42 PM
Ponch95's Avatar
Default Fan Fuse issues
Okay I cannot keep a fuse in my fuse box when it comes to the fans as soon as I put one in and reconnect the battery it blows, maybe I'm missing something simple here but it's frustrating me to no end.
I have a SLP fan swith installed (Correctly), but just don't see why it keeps blowing.
Old Mar 28, 2008 | 03:54 PM
2001NBMZ28's Avatar
Since the SLP switch is plug and play first thing I'd try is unplugging it and reconnecting the stock connectors - if nothing else it'll eliminate the SLP switch or connector as the problem.
Old Mar 28, 2008 | 04:24 PM
Ponch95's Avatar
did that..still have the issue grrrr
Old Mar 28, 2008 | 07:17 PM
Ponch95's Avatar
Okay I disconnected both fans, put a new fuse in, reconnected the battery and it blew the fuse. I pulled all the loom off looking for a shorted wire but can't seem to find one.
I need help here guys.
Old Mar 29, 2008 | 03:58 PM
Ponch95's Avatar
Okay update: I used my connection tester on the fuse junction and pulled all 3 Relays, I get a light on 1 prong off 1 & 2 Relay but get nothing off the fuse prong and # 3 Relay.....thoughts?
Old Mar 29, 2008 | 07:10 PM
joshp14's Avatar
By disconnecting the fans before you hook the battery up you are eliminating the fans as the culprit. Now is the time to get out your DMM and a wiring schematic and start looking for a short to ground.
