Sponsored by: CARiD
A/C compressor lines
Old Mar 29, 2008 | 09:45 PM
mikex70's Avatar
Default A/C compressor lines
Whats up
My A/C compressor went out last summer and i had to swapped out for a bypass and it was way to hot in my car all summer so im looking to throw one back on and charge the system back up but i have a problem, There is supposed to be a plate that holds the lines in and i dont have it. I bought a used compressor and went to put it in only to find the fines dont stay in without the plate, so what i need to know is where can i get one or can i use an A/C fitting to hook up the lines( like the ones in the pic.
Please help me out.
Pic 1: the compressor with out the lines not on my car found the pic
Pic 2: SHbox diagram, is #10 the plate? if so no the part #
Pic 3: A/C fittings will they work or leak?
Thanks for the help
Old Apr 6, 2008 | 12:25 PM
mikex70's Avatar
Guess ill give it a shot
Old Apr 16, 2008 | 07:18 PM
Crimson's Avatar
I hope you put a vacumm pump on your lines and run dry nitrogen through it 3 times to pull out any moisture.
