Battery Voltage? The problems never end!!!
Aright guys heres the full story. last week i picked up a 2000 SS M6 with only 45k miles on it. i buy it, then drive it three hours home without a single problem. about 5 days after i got it home, i noticed the battery voltage was getting lower and lower every day(right at 13 actually) I had the battery replaced, and today replaced the alternator myself. After all that, the voltage is still right above 13!!!! it was halfway between 13 and 18 when i first cranked it after the alternator install, but then after cruising for about 20 miles remained firmly right above 13. When i got the new battery and was heading home, the car kept wanting to stall, so i kept burning the clutch and kept the RPMs as high as possible. Now i am currently running seafoam through the car, and then plan the change all fluids after it is completed. What could be the cause of my newfound problems? I havent been ******* it and have been driving it as normally as possible, about 2 grand shifting. On another note, i also lost the alternator bracket bolt and now need to order a new one, but from where? Also, the car was only driven 4000 miles in the last few years, so that could have something to do with it. I really appreciate any advice you guys have! thanks
