Sponsored by: CARiD
IP Dimmer fuse keeps blowing
Old Apr 2, 2008 | 11:03 PM
Smoke Panther's Avatar
Default IP Dimmer fuse keeps blowing
the little 5 amp fuse for the IP Dimmer (the thing that lets you see your gauges at night) keeps blowing; I went thru a pack of 5 in a 17 minute drive. Would it be ok to get a higher-amp fuse, or is there some other problem that needs adjusting?
Old Apr 2, 2008 | 11:12 PM
SparkyJJO's Avatar
If the standard original fuse is 5A then don't put a higher amp fuse in. Can be a bad idea, you could cause even more problems upping the fuse. I'd look and see why it is blowing. Do you have any aftermarket stuff hooked up at all?
Old Apr 2, 2008 | 11:20 PM
No, the interior of my car is all stock, the dash has never been pulled apart
Old Apr 3, 2008 | 10:13 PM
Formula413's Avatar
I'll just throw this out there: remove the console and check the wires that go to the bulb that lights up the shifter display (if you have an Automatic). I just had to change that bulb and I was looking at it thinking that it would be easy to get the wires to it pinched by the shift linkage. It's worth a shot. You could also check behind the stereo. Maybe the dimmer **** has some sort of short in it? Hopefully it's not something behind the dash. Good luck, let us know if when you find the short.
Old Apr 3, 2008 | 11:13 PM
GregWS6&z28's Avatar
his car is a 5 speed
Old Apr 4, 2008 | 12:35 AM
Formula413's Avatar
You mean 6 speed.
Old Apr 4, 2008 | 10:34 AM
Originally Posted by Formula413
You mean 6 speed.
No, he was right
Old Apr 4, 2008 | 04:11 PM
Formula413's Avatar
Originally Posted by Smoke Panther
No, he was right
V6???
Old Apr 4, 2008 | 05:36 PM
^yea.
Any ideas on how to make it so I can see my gauges at night? Anything in particular i should look for that wouldn't be glaringly obvious?
Old Feb 6, 2009 | 07:53 PM
99Z2ate's Avatar
I am having the same problem as this guy did...the IP Dimmer fuse blows whenever I put another one in. I have a 99 M6 Camaro and I also have an 01 at the house if I need to switch parts around to figure out the problem. My brother says it's a short-to-ground. What do you guys suggest doing first???
Old Sep 25, 2011 | 07:09 PM
shadowfox's Avatar
I looked a lot of similar posts on this issue but no clear idea of what caused it?
Any chance you managed to resolve this issue with the 5amp fuse blowing for the IP Dimmer? I have the same issue on my 94 trans am, It seems to be a fairly common problem even with fully stock cars so I don't see any mods being relevant and none of mine were electrical anyway.
Old Sep 27, 2011 | 01:50 AM
94'BLKBRD's Avatar
^^^ Have you removed or replaced any parts recently?
Old Oct 1, 2011 | 05:36 PM
shadowfox's Avatar
No, I haven't, that would have been the obvious place to start. Nothing changed from when it was working to when it stopped, and there is no obvious reason to me of why it did. But without fail, it blows the fuse if you replace it. I looked around for wires that might be worn/burnt/poorly grounded/touching but I couldn't find anything.
Old Oct 1, 2011 | 07:44 PM
jam01's Avatar
bad switch.
Old May 18, 2019 | 10:43 PM
Sodabomb's Avatar
Did you ever figure out what the problem was?
