Oil filter cleaned now SES flash help please!
Should the misfire go away after the car runs a while? I only turned it on and let it idle for 1-2 mins and only took the rpms up to about 2,000 because i wanted to avoid hurting anything. Wanted to know if the misfire goes away once the fuel system gets back on track from having a clean MAF or if it should fix right away and this is a sign of something else. Sorry i dont have the ses scan numbers.
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses under the hood
Wait 5-8 min
Turn ignition off
Replace fuses
If there was that much oil on the filter I'd clean it again, let it dry, then re-oil lightly - or just put a paper filter in. Could also be a coincidence and something else is going on.
When i was in the car after putting the newly cleaned MAF in the SES light was not flashing, just sitting on. The car was still vibrating like it was before except no flashing light. I figured that the engine might still be coughing because of the dirty MAF and need some time to get back on track but i didnt want to go drive it and have the car blow up on me. I also just unplugged the battery and read that the car will idle grumpy while it relearns, how long should i wait and should i just sit and idle or should i drive it around the block?
Hopefully nothing else is going on unless it was caused by the MAF being dirty and lead to another problem. I just got the car back from getting the computer reprogrammed correctly (first mechanics that put my new CPU in did not program it right then said they did not have the program to redo it.)
Im pretty sure everything going on is Filter oil---> MAF related. I am also probably going to buy a code reader just to have because trying to fix cars yourself is interesting and gives me more knowledge when i bring it in to a mechanic.
K&N needs to take their stupid instructions on their recharge kit and rewrite them, it specifically says "LIBERALLY APPLY OIL" and goes on to explain its red oil so you can make sure you dont miss any spots. Lol, i thought i was doing a good job by making sure the thing was all covered not actualy hurting it untill i came on here to read why the light would come on after cleaning the filter.
It sits at around 700 rpms in idle and the vibrations of the car remind me of my friends 550 hp mustang gt. Very bumpy and if you rev it the exhaust has a much more throaty sound that just recently developed with the vibrating and flashing SES.
Good news is the SES is not flashing anymore, just sitting there lit up.
When i cleaned the MAF i used the MAF cleaner but also used q-tips to wipe the grime off the wiring which i belive was needed because i sprayed the wires, let it dry then sprayed it again and wiped them and black residue was getting on the q-tips so the initial spraying didnt remove anything.
Maybe the MAF being dirty caused a sparkplug to go out? the car has about 47,000 miles on it. Or it overworked an o2 sensor and one of those fried? I dont really know what else causes the misfire.
I cleaned the maf, unplugged battery for about 40 mins to reset computer but i have no idea if i need to sit and idle for x amount of time to know if the car is working now or if its still busted and something else is wrong.
http://www.knfilters.com/MAF/massair.htm
I had major MAF problems (black stuff like you are describing) and my symptoms were only under acceleration. I never had any misfiring or problems at idle.
In the end, I had to disassemble my MAF and clean the contacts with MAF cleaner and a q-tip. Of course, the element is a very fragile piece and I was very careful. I also used a magnifying loupe to do the work, which made it a lot easier to see the contamination and the results of the cleaning.
The shop i go to is open tomorrow so im just going to see what they have to say, hopefully the damage isnt in the 4 figure range.
You are making a reasonable assumption regarding the relation to the oil on the MAF. That may well be it but it is still an assumption. Swap in a known good MAF and see how it runs. If it still runs like crap, you have a bigger problem and need to start going down the list and eliminating stuff.
If it were me, I would swap in a MAF. IF that doesn't do it, have it towed to a shop you trust.
I dont have the luxury of having another working MAF laying around so i cant just stick one in lol.
