Sponsored by: CARiD
Please help driver side panel (replaced window motor)
Old Apr 11, 2008 | 05:01 PM
koz28's Avatar
Exclamation Please help driver side panel (replaced window motor)
Hi,
(I have a 1998 z28)
I just got my window motor replaced by our local mechanic and the panel where the buttons are (door lock, window controls etc.) is not attached. How is this panel suppose to be held in? I think maybe a plastic piece might have feel off and thats why I cant figure out how to hold the panel in. Right now I have some compound and a clamp holding it in place to see if that will work. Any suggestions on what else I can try? Thank you
Old Apr 11, 2008 | 05:37 PM
2001NBMZ28's Avatar
It's held in place by a spring clip on each side, slips into the "ears" on the panel. Maybe they lost them or broke the slots they slide into? Hang on and I'll post a pic link.
Old Apr 11, 2008 | 05:41 PM
koz28's Avatar
Great Thank you since it is probably broke anywhere i could order one?
Old Apr 11, 2008 | 05:44 PM
2001NBMZ28's Avatar
http://shbox.com/page/W1.jpg
93-02 Camaro GM PN is 9722397 Not expensive, probably a dealer item.
Old Apr 11, 2008 | 05:54 PM
koz28's Avatar
I appreciate your fast response that solved my problem Thanks
Old Apr 11, 2008 | 06:05 PM
Shooter_Jay's Avatar
there are screws that should hold it in place.
Old Apr 11, 2008 | 06:11 PM
2001NBMZ28's Avatar
No screws on mine. Broke one of the ears the clip slides into on mine first time I did a window motor swap and panel wouldn't hold. Super glued it back on and has been holding fine.
