Sponsored by: CARiD
Suspension Problem Please Help.
Old Apr 26, 2008 | 07:30 PM
fspalt's Avatar
Default Suspension Problem Please Help.
Whenever its cold out and i go over bump I hear a sound coming from the left rear wheel area. Its happens a the car bounces over the bump. It sound cruchy like if you sqeezed a rusty spring together. When in park i can press down on the left rear fender a couple of times and make the sound. It doesnt seem to happen when its warm out. Is this a bad shock or could it be something else?
Old Apr 26, 2008 | 07:42 PM
Blackhawk777's Avatar
Sounds like weak bushings. Mine's doing something similar and that's the problem.
Old Apr 26, 2008 | 08:39 PM
Crimson's Avatar
I have a similar problem, how do you tell which bushing it is?
Old Apr 29, 2008 | 07:10 PM
It's usually the LCA bushings. My swaybar ones and the tq. arm mounts are solid.
Old Apr 29, 2008 | 08:11 PM
ae13291's Avatar
mine ended up being the sway bar bushings! i removed them and greased them and never had that problem again!
Old Apr 29, 2008 | 10:29 PM
fspalt's Avatar
What do you look for when checking for bad bushings?
Old Apr 29, 2008 | 11:11 PM
fspalt's Avatar
Looks like it was the Rear Lower Control Arm Bushing. How can I go about changing it out and where can I get one?
