Sponsored by: CARiD
how to use ramps
Old May 13, 2008 | 04:49 PM
slayerized6's Avatar
Originally Posted by 9000th01ss
I stick my head out the window and drive right up with an M6.
Using a jackstand with ramps is useless. If the car isn't resting on the stand it's going to roll down the ramp or tip over sideways, by the time it hits the stand it's just going to tip it over.
The worst experience I had with ramps is pulling a valve body off and having the linkage move the parking pawl out. The car rolled back a few inches before hitting the wheel chock.
can you even see the tire/ramp with your head out the window?
Old May 13, 2008 | 04:51 PM
robertbartsch's Avatar
Where are jack stands, ramps and floor jacks made today?
China; right? Sure these are designed to take the weight, but their dog food was not designed to kill millions of our pets either! Trust a Chinese ramp, floor jack, jack stand, etc. and you may be "flat" out of luck!
Old May 13, 2008 | 05:28 PM
troopercar's Avatar
not unless his camaro is different than mine
or he has an osterich neck
Old May 13, 2008 | 05:30 PM
troopercar's Avatar
apparently anything other than a hole dug in the ground (and a trench box) is not good enough for you
Now you've kinda freaked me out with all the mental images of having my head pinned to the ground by the headers.
Old May 13, 2008 | 06:18 PM
landonew's Avatar
Sooo, you would recommend?
I always just use two jack stands. Feel pretty safe, but what do i know?
Old May 13, 2008 | 06:58 PM
9000th01ss's Avatar
No I just do that to catch a breath of fresh air.
Old May 13, 2008 | 07:22 PM
99z28monster's Avatar
And if you have keep up with current events you can see that karma has dealt them a nice blow.
Old May 13, 2008 | 07:24 PM
You might have to leave the door open and lean out a bit to see. Its not like you are sitting like you are driving down the road. real easy to do.
Old May 13, 2008 | 07:25 PM
9000th01ss's Avatar
Heres a short video, take one because it was getting dark. I could have kept doing it until I got it perfect, but this was a quick set up and go, just for this thread.
http://www.youtube.com/watch?v=QjKVyJRopZk
Old May 13, 2008 | 07:37 PM
9000th01ss's Avatar
No I leave the door shut to lean on it. If I do it with the door open it blocks my view and makes me feel unstable.
Old May 13, 2008 | 07:38 PM
hahaha thanks for making a video
Old May 13, 2008 | 07:41 PM
  #32
sorry bro didnt mean to quote you meant to do the guy who was asking how you could see the ramp.
Old May 13, 2008 | 07:52 PM
  #33
Formula413's Avatar
Meaning that 10,000 random Chinese people deserve to die because some Chinese made products are of inferior quality?
Old May 13, 2008 | 08:44 PM
  #34
yep thats just what I was going for. And you think outta 10k they were all inocent? Sinners will be punished
Old May 13, 2008 | 11:37 PM
  #35
needadvice's Avatar
wanna hear something as funny as this thread is getting. A friend of mine....his father has tree triming service. His dad brought home these two badass stumps he pulled pout of someones yard. They are about 2 feet in diameter and about 2 feet high. Perfectly flat cut on the bottom so its planted on the ground, even if the car rolls backwards they cannot tip over like jack stands or a jack can. No welds to break, no seals to leak or blow. And they can easily support 10,000 pounds, each. They weigh like 50 pounds but slide across his garage floor with one finger pushing them.
Thats what he uses under his car for safety jack stands. He's got two hydraulic floor jacks to get the car up.
Old May 13, 2008 | 11:43 PM
  #36
needadvice's Avatar
$45.00 total cost, and safe.
Lift the car with this:
http://www.jcwhitney.com/webapp/wcs/...atalogId=10107
Then, jack stand the bitch:
http://www.jcwhitney.com/autoparts/I...D:100000422187
Old May 13, 2008 | 11:51 PM
  #37
i got the same exact jack and jackstands. good for lifting at the wheels, but now at the k member or differental
Old May 14, 2008 | 12:05 AM
  #38
haacer's Avatar
I don't have the SFCs, but ramps work just fine with my M6. Mine are some cheapo Wallmart jobs with plastic extenders that clear my ground effects. I usually put the ramps right up against the tires and then have someone watch as I drive up. Once or twice and you'll be a pro... I've seen jackstands tip and jacks fail.... Hydraulic lifts can fail for that matter too.
My ramps are idiot proof, once the car is on them it isn't going anywhere. That's good for the idiot crawling underneath (me).
Old May 14, 2008 | 12:16 AM
  #39
needadvice's Avatar
If you have two jack stands and a jack, why would you have to ever lift at the K or diff?
Just do it on one side, install a jackstand, then lift the other side and install the other jackstand. The car is now safely in the air, you can work on anything just like lifting at the k or diff.
Old May 14, 2008 | 12:44 AM
  #40
Grimes's Avatar
Okay, that comment is a little bit ridiculous. So i guess the school that collapsed and buried 900 kids alive fits into your equation how?
