Sponsored by: CARiD
another window question
Old May 14, 2008 | 10:58 PM
scook179351's Avatar
Default another window question
Ok, the passenger window will not go down. So i removed the motor and tried it while it was not onthe door. The motor will rotate to raise the window up but it will not rotate the opposite direction to lower. So I brought a new switch and that didn't fix the problem.
Anyone else here had this problem. I have a '94 model.
Old May 15, 2008 | 09:40 AM
Camarojunkie's Avatar
Which switch did you replace? If the drivers(master switch) is bad then even a new one on passengers side wont work. Just take jumper wires to the motor and make sure it will turn both ways to make sure its the switch, if it wont then its the motor.
Old May 15, 2008 | 09:37 PM
I also tried a new motor on the passenger side and it would only rotate one way also. So I guess that I'm gonna buy the drivers switch and see what happens, their cheaper than a motor.
