Sponsored by: CARiD
check engine light
Old May 22, 2008 | 02:37 AM
FormulaZ's Avatar
Default check engine light
I head on my way home from work and my check engine light goes on, it has done it before while im stopped at a light, but goes away when I start driving. This time it didnt go away, so I pulled over, shut the car off and restarted it and it went away.
I just installed a set of LT headers and y-pipe, no cats and still getting around to the ovc wires as well as a small oil leak (I think when I installed the cap and rotor to the opti I might have forgotten the o-ring or seal).
I also felt a vibration as I came to a stop, it lasted a moment then stopped as I stood at a light or stop sign.
Not sure if anyone has any ideas, I wont be able to scan it till tmw night. I checked the wires though, they looked ok. Only ideas I have are opti or o2 sensors. Any help would be appreciated.
Old May 22, 2008 | 09:23 AM
keliente's Avatar
Let us know what the codes are after you scan it. Without 'em, we're shooting in the dark.
Old May 22, 2008 | 09:25 AM
tomustang's Avatar
After the code is scanned, you would also point it to when it started happening, probably when you worked on something, should narrow it down
