Have a Brake Issue
1) Now the brake pedal in more spongy than before.
2) The left front brake (which had the worst rotor of all, but never made any noise) is now grinding even when not under braking. Obviously, the pad is riding right on the rotor for some reason.
Any help / suggestions would be appreciated. FYI, I did NOT bleed any brake fluid from the system during the entire process, so I don't know how I could have possibly gotten air in the system.
As for the grinding noise, I would make sure the caliper slides move freely. How bad off is the rotor? Maybe before you took it apart the pad was sitting in just such a way as to not produce this noise, and putting it back together left it in a slightly different position.
It's funny you mention this because I just changed he pads on my daily driver and I have the same grinding noise they were making before the new pads, but only when applying the brakes.
Anyone have a good method for dislodging caliper pins?
