Sponsored by: CARiD
I need some help
Old May 24, 2008 | 10:23 AM
axcellclan's Avatar
Default I need some help
I have a 01 SS and the service vehicle light stays on. This is not the service engine soon light and I have been told it will take a combination of pumping the brake, gas pedles and turning the car on and off to turn the light off. All the dealerships services are closed for the weekend out here so they are no help. Does anyone know what needs to be done to turn this light off? Please help if you can. Thanks.
Old May 25, 2008 | 06:04 PM
joshp14's Avatar
You will have to get the car scanned with a scan tool to see what the code(s) are so you can fix the problem. A generic scan tool typically wont communicate with the BCM to pull these codes so you may have to take it to a shop that has a more advanced scan tool to pull the codes. I've never heard of a method to clear the codes other than clearing them with the scan tool.
Old May 26, 2008 | 01:38 AM
Formula413's Avatar
Do you mean the oil change light? To turn that off, turn the key on (engine off) and push the throttle to the floor three times, this resets the oil life monitor. Don't forget to get your oil changed.
