Sponsored by: CARiD
AC belt squeaking, nothing helps
Old May 24, 2008 | 04:57 PM
9000th01ss's Avatar
Default AC belt squeaking, nothing helps
When I put my AC belt back on my car it was squeaking so I greased the bearings, didn't help, changed the belt--didn't help, put on a Gatorback belt--it helped for about a week, now the noise is back. What the hell do I do now?
Old May 24, 2008 | 05:35 PM
Grimes's Avatar
it might be the actual ac compressor. you can try buying a new tensioner/pulley assembly first though. That did it for me - if the tensioner is too weak, it will trash the belt and cause squeaking
Old May 24, 2008 | 06:07 PM
94'BLKBRD's Avatar
Try replacing the tensioner
Old May 24, 2008 | 07:52 PM
9000th01ss's Avatar
I'll try the tensioner. When the original belt started making noise I sprayed oil on it to see if it was making the noise, it goes away when I spray the inside of the belt.
Pretty sure it's not the compressor.
Old May 24, 2008 | 08:36 PM
2SLOWT/A4NOW's Avatar
Check all your pulleys too for cracks and/or junk down in the grooves. Don't forget the idler pulley also. I'm not really a fan of any kind of belts but OE. Had to many problems with anything but. Especilly ones from that company with 4 letters.
Old May 25, 2008 | 06:31 AM
marthyh's Avatar
Maybe pulley alignment issue ?
Old May 25, 2008 | 08:52 AM
I thought of the alignment issue too and failed to mention it. If a pulley is worn it can cause the belt to wear funney and start making noise soon after replacement.
Old May 25, 2008 | 08:53 AM
Luder[PAK9]'s Avatar
Does it squeal all the time? Or does it not do it on certain days or go away after awhile? My belts squeal for a for a few minutes at start up just from the dew/humidity on them.
Old May 25, 2008 | 09:40 AM
9000th01ss's Avatar
It squeaks all the time, AC on or off. The gatorback belt was dead quiet but it's slowly getting a steady squeak back.
I'll have to check the alignment, the first ac belt was the original GM belt with 82,000 on it. It started making noise before I even put the condenser back in the car.
The main belt is the original GM belt and is quiet.
PS I bought the car as a roller and got a complete junkyard engine complete with the belts still on it. I had the compressor off during the engine installation, put it back on with the wire unplugged until I got the rest of the AC installed.
