Weird Window Noise
Anyone else have these problems or can suggest something? The car only has 14K miles on it, hopefully it isn't anything serious.
Thanks.
-Collin
Does the noise only happen in one place or does it keep going on through the full motion?
Thanks for the help.
If so, you might check the bumper that the window rests on to make sure its in right. If you take off the door panel and take out the door speaker, you should see a rubber bumper towards the front of the door. The glass rests on this when its all the way down. The bumper locks in a slot cut in to the bottom of the door. If its out of place, it can make a dull thud.
You could also have a loose regulator. With the door panel off, watch the regulator rivets/bolts and make sure they don't move when you hear the noise.
