Need help starting problem 00 SS
First I'd pull a plug and check for spark. Do you hear the fuel pump prime when you turn the key on? If not you either have a bad pump, bad relay, or possibly a Vatts problem (if the security lighy is on). If the above is all OK check for the injectors working as stated above. If you have spark though the injectors will be working. If you have no spark or injectors you could have a bad cam or crank position sensor. You also didn't mention if the SES light is on. If so scan the PCM as it may tell you what is wrong.
Re'
BTW - Check your fuel filter and fuel pump and/or pressure.
Thanks,
Craig.
LS1TECH.com Staff
