Sponsored by: CARiD
3rd gear
Old Jun 15, 2008 | 07:23 PM
RedBird2001's Avatar
Default 3rd gear
just bought a Trans am and it only has 6,000 miles on it and it keeps popin outta 3rd gear......what could this be?
Old Jun 16, 2008 | 09:47 AM
wssix99's Avatar
Save the manuals!
Check to see if you have a Hurst or other aftermarket shifter with positive stops. If so, the forward stop my just need to be backed off a bit so you can get the stick all the way in to 3rd gear fully.
Old Jun 16, 2008 | 10:33 AM
Elliott's94Z's Avatar
So in third it will free rev if you step on the throttle? Sound like the same thing a fellow member had and it ended up being a bad forward sprag
Old Jun 16, 2008 | 01:26 PM
ae13291's Avatar
maybe the tranny is gone but i dought at that miles! maybe its the keys or bloker rings
Old Jun 16, 2008 | 07:56 PM
yes it has a hurst shifter.......i think ya hit the nail on the head there i'll see what i can do thanks
Old Jun 16, 2008 | 08:18 PM
9000th01ss's Avatar
This guy here has a manual transmission.
Old Jun 16, 2008 | 08:59 PM
CRAGER's Avatar
Administrator
You can also check out the Manual Transmission section. I'm sure you'll get some help in there.
Peace,
Craig.
Old Jun 16, 2008 | 09:31 PM
2000ramairformula's Avatar
You got a bent third gear shifting fork...I have the same thing wrong with mine. It's from hard shifting to third gear and if it has the factory hurst shifter then it will bend. I put a good shifter in mine w the stops after the fact. So I just skip third for now until I get the $ to fix it right. I know this because I already tore into mine and replaced the dogs and plastic pieces that were broken and thought that was what was wrong and it wasn't. D & D performance told me that it was most likely a bent fork and they would know bc thats all they do and thats their specialty.
Old Jun 17, 2008 | 07:18 AM
wssix99's Avatar
Save the manuals!
With the mileage of the car, the adjusting screw is probably the issue. It took me an extra adjustment to get my Hurst right so it wouldn't pop out like yours is doing.
Old Jun 17, 2008 | 04:40 PM
thank yall for all the advice......
Old Jun 18, 2008 | 02:35 PM
It doesn't take but just a few hard shifts to third to bend it....just call D&D for advise.
