Leaking oil and trans fluid...What to replace?
Thanks
Your car lowered, non adjustable torque arm?
Your pinion angle may be off causing these issues. I wouldn't recommend attacking the pinion seal. There are a few steps (such as setting pinion depth) that I'm going to assume you won't be able to tackle.
Driveshaft comes out @ the rear first with 4 bolts. Mark the driveshaft position before removing and slide it out of the trans.
You'll need a seal puller or carefull hands with a flat blade screw driver and hammer to get the seal out. Then you'll need to press it back in with either the appropriate tool, or very very carefully with a sizeable socket + hammer.
So the output shaft seal and pinion seal need to be replaced. I'll have to have my shop take a look at it next week. Thanks
It's a rare occasion to see a 4th gen with a factory 10 bolt that doesnt leak from the pinion seal.
Good luck!
