Sponsored by: CARiD
Radiator Repair
Old Jun 27, 2008 | 06:53 PM
BLASTER's Avatar
Default Radiator Repair
Was installing stuff on my truck and punctured a small little area on the top of my radiator. I thought I only got some of the fins so it was no big deal but when I started it up a small little stream of coolant was pouring out.
Can this be repaired or do I have to buy a new one?
Also, should coolant be leaking out when I first start the truck? It doesn't leak when it's off so if it comes out when it first starts running due to pressure then my thermostat must be stuck open? Does that make any sense?
Thanks
Old Jun 27, 2008 | 08:11 PM
2SLOWT/A4NOW's Avatar
Any competent radiator shop should be able to fix it.
Old Jun 27, 2008 | 08:15 PM
Pinnhead13's Avatar
yeah take it to a shop. they'll most likely patch it up.
Old Jul 6, 2008 | 12:06 PM
BLASTER's Avatar
Very small hole so I used JB Weld and it sealed it.
Old Jul 6, 2008 | 08:12 PM
samson_420's Avatar
Ah JB Weld, is there anything it will not fix. . . ?
I would not really leave JB Weld on a radiator too long, it will break.
Old Jul 6, 2008 | 11:20 PM
BLASTER's Avatar
I've heard others use it with success so I thought I would give it a try. It was a tiny pin hole. I really don't want to have it give out on me will I'm driving.
Old Jul 7, 2008 | 08:17 AM
FLA02TA's Avatar
I did the same thing when installing a trans cooler (drilling accident, don't ask). 25$ at a local shop and it's good as new.
