Door skin is seperating.....what glue?
The leading edge of the door skin, from the trim up, has seperated. I can pull it apart enough to run a new bead of adhesive on it, but what should I use?
Can I use something from like a Walmart, or do I need something special from a body shop?
The only real difference between the two is the 9313 isn't quite as viscous so it flows better. If you want it to stay right where you place it use the thicker 9309.
