Sponsored by: CARiD
Battery voltage question
Old Jul 2, 2008 | 06:38 AM
OldskoolRcr's Avatar
Default Battery voltage question
What is good voltage with the car warm, and lets say under WOT?
Old Jul 2, 2008 | 08:17 AM
Delaware ss's Avatar
Mine runs between 13.2 and 13.6 all the time
Old Jul 2, 2008 | 02:16 PM
RsSean's Avatar
14.1- 14.7 is what mine is running. Anything under 12.0 the car won't start. With a car just started the voltage should climb from 12.6 up to 14.1-7. IF all other eletrical system are working right and no draws on the car I.e stero boom boom, lights etc.,
Old Jul 2, 2008 | 02:24 PM
jmilz28's Avatar
It's also noteworthy to use a separate meter, your gauge on the dash is simply a reference and not all that accurate. Even more important than voltage output is amperage output, of both the battery and the alternator.
Old Jul 2, 2008 | 09:11 PM
Hum...Mine runs at 13.0 after its warmed up, I am having a issue with my N20, and I think it may be voltage related, I am going to check it with a volt meter N/A and I am going to activate the spray and see what the voltage drops to. I can be driving 65 down the interstate and it is at 13.0 all the time, so after the spray is activated and the big fuel pump it may be the issue. If I am driving at 65 and turn on the 2 bottle heaters it drops below 13.0, till I shut them down. Thanx for the input.
